diplomat 8245 error lights
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat 8245 error lights
  • #5719
    hi my diplomat dishwasher has packed up I have three flashing lights from the left and the far right light is staying solid. It starts the cicle emptys water then fills up then beeps and the lights come on. Diplomat told me to try a reset which i did but no joy. Any ideas what it is so I can get which ever part is knackered on it.
    cheers
    #113298
    Re: diplomat 8245 error lights
    Hi I am getting the same problem. I took the machine totally to bits including every hose and wire. I rebuilt it but still hgave the same problem.
    The manual does not show this particular error.
    Any ideas what it is ?
    #113299
    Greetings, oh pink spotty one. There was a duplicate of this thread running back in July, where the answer was found.
    Seemingly the digiboard is looking for a component which is not actually fitted to your appliance! The only solution is to “reset” the computer, which is a bit of a specialised job.
    Best bet is probably to get some professional help. Check in the Directories for a UKW engineer in your area or pop your postcode up here and someone will pick up on it.
