been useing this machine for 16 months with no problems but now it wont work, i’m getting 4 flash’s then a pause then repeating same, any ideaswhat the problem is ??
4 flashes indicates a draining problem.
Check all the usual stuff, blocked filters, blocked drain under the sink and also check for a flooded base in the dishwasher.
Please remember to turn the power off before doing anything.
Hi DP Did as you said and found blockage in hose, that i unblocked. washer then worked on one rinse cycleand then went back to 4 flashes, and no water going into washer, daft question but does washer have to be fullof dishes for it to work
