Re: diplomat 8332 dishwasher
Flow meter failure – not a 5 minute fix. Remove machine from housing, remove left hand side panel to reveal water matrix. Flow meter is a water wheel and pcb assembly. Usually a good clean of the contacts and a squeeze of the connector will get things going again, although the reed switch on the pcb can fail in which case a new matrix will be required.
If you are unsure how to proceed, put your postcode into the repairs@ link to find a local UKW engineer.
Power off if you intend to try and do this yourself.
