Diplomat 8332 problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat 8332 problem
  • #62535
    llewelynlad
    I have a Diplomat 8332. When i run the program at any temp it runs for about 30 seconds and then stops with a constant bleeping. The bleeping stops when the door is opened but to start light flashes continuously. If the machine is run on rinse it just stops with no bleeps.
    There appears to be no water but it drains and the water feed is on.
    Any help would be appreciated.
    #350381
    nigegt
    Re: Diplomat 8332 problem
    Check that the start light is flashing cont. and there is no one second gap as this is a fault code so count the flashes and post again or if there is no gap then the ntc is faulty.
    Nige
