Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat 8502 not working
- This topic has 9 replies, 4 voices, and was last updated 17 years, 4 months ago by
DUCKLEBUM.
December 7, 2008 at 5:14 pm #41664
DUCKLEBUM
ParticipantHello,
I seem to be having a problem with my dishwasher.
When I press the start button, the machine sounds like it is beginning to work for 20 or 30 seconds and then stops. The green light is flashing in 2’s, what does this mean? and how can it be fixed?Very grateful for any help
DBDecember 7, 2008 at 7:53 pm #270927Penguin45
ParticipantRe: Diplomat 8502 not working
Flood protection activated – there is water in the tray under the machine. Drain off and find the leak.
Power off before removing any panel.
December 8, 2008 at 10:51 am #270928DUCKLEBUM
Thanks Penguin 45.
Is this relatively easy to do? can I do this myself?
If I can identify the leak, what is the best way to ‘plug’ it?Vbrgds
DBDecember 9, 2008 at 12:25 am #270929Penguin45
Remove plinth, decor door (slacken screws 2 + 4 each side of door and push down), then the lower cover plate. If working with the machine “in situ”, simply bend the front edge of the tray down with a towel in place to drain. The leak itself can be awkward – a torch and observation may be the only way. Bear in mind that it has the BIG ASKOLL circulation pump fitted, with all the problems which that entails.
Stay safe, power off for anything other than observation.
December 9, 2008 at 2:29 pm #270930DUCKLEBUM
Thanks again Penguin 45.
I will give this a whirl tonight and let you how I get on.
Hopefully I can sort this out!Vbrgds
DBDecember 9, 2008 at 7:34 pm #270931DUCKLEBUM
Right, I managed to drain the water from the tray below as you said.
However I am finding it hard to see exactly where the leak is coming from. Is the BIG ASKOLL pump on the right at the back?
Should I set the machine running and see what I can see?Man thanks!
DBDecember 9, 2008 at 9:00 pm #270932Penguin45
Pump is at the rear right. This might help:
Did you click on the link?
December 11, 2008 at 8:24 pm #270933DUCKLEBUM
Many thanks, your picture was most helpful.
I also checked out the link about the BIG ASKOLL.I drained the tray and ran the cycle again, watching intently with torch in hand. It did seem like the water was spraying out from the outlet hose from the dreaded ‘ASKOLL’
I then drained the tray once more and removed the side panel to confirm this was where the water was coming from.However now the water is not leaking at all and the cycle is stopping and the green light is flashing in 6’s!
Can you tell me what this means?
Thanks again for taking time to help me. Even if it can not be fixed,I am learning a fair bit about dishwashers! lol
Vbrgds
DBDecember 15, 2008 at 9:50 pm #270934karv
f6 not filling with water, when the motor starts its turn the small leak into a spray and all the wires get wet and can give u tons of fake faults, untill it drys out or you have turn the water of or have a kinked pipe or faulty valve.
December 24, 2013 at 10:40 am #270935bigblaz
Penguin45 wrote:Remove plinth, decor door (slacken screws 2 + 4 each side of door and push down), then the lower cover plate. If working with the machine “in situ”, simply bend the front edge of the tray down with a towel in place to drain.
Thanks Penguin45 – a Christmas Eve lifesaver!
