Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Diplomat 8512
- This topic has 13 replies, 8 voices, and was last updated 17 years, 7 months ago by
JOHN CLARKE.
August 20, 2008 at 2:46 pm #38891
JOHN CLARKE
ParticipantHave a Diplomat 8512, will not spin, it acts as though the “NO SPIN” button is pressed in, but I’ve disconnected the button and also bridged it out, which makes no difference. I,ve fitted a new module (from EMW) but still no spin, I did squeeze up all the edge connectors. The heating element checks out OK. It has a induction motor fitted. Please has anybody got any ideas where I go next.
August 20, 2008 at 3:52 pm #260265wilf
ParticipantRe: Diplomat 8512
pressure switch or blockage?
wilf
August 20, 2008 at 6:35 pm #260266JOHN CLARKE
There is no pressure hose blockage. Is the Pressure Switch a one level switch as I only get one click when I blow up it ?
August 21, 2008 at 6:47 am #260267Dales-Electronic
ModeratorRe: Diplomat 8512
Have you checked the windings on the motor, with it being an induction motor it has two windings, one set for spin and one for wash also check the start capacitor is OK. Finally, make sure the belt is very tight.
August 21, 2008 at 6:49 pm #260268JOHN CLARKE
Motor seems ok it speeds up ready to spin so I think the spin windings are OK, worth a check though, the capacitor is OK as it serves for the wash windings as well and there is nothing wrong with wash side. Think I’ll go for the pressure switch, but keep the motor in mind, bet they cost an arm and a leg.
August 22, 2008 at 7:07 am #260269Dales-Electronic
Check the belt too as these will not spin at full bore if the belt is not really tight
August 22, 2008 at 7:58 am #260270Simon46
I was caught out by a belt after replacing module 😆
S.
August 22, 2008 at 7:29 pm #260271JOHN CLARKE
Well the Belt looked tight although I never checked it, I will now check that, never known that to be a problem before though. Still at this stage I’ll believe anything.
August 22, 2008 at 10:28 pm #260272leavemetogetonwithit
Don’t know if this is one of these machines that has to have a full load in before agreeing to spin?
Mike.August 23, 2008 at 7:26 pm #260273lerch
They do have a habit of not spinning without clothes in but also as said before belt must be tightened and then try with 3-4 towels and should spin. 😀
August 24, 2008 at 10:07 am #260274eastlmark
have you left it long enough? they take an age to spin and you must start the spin prog exactly on the start of the programme. one click past it and it will not spin, ideally start it on the end of the rinse programme and let it run through. Should be a good 3-4 minutes of pump and fwd/reverse drum action before it will ‘pause’ (all goes quiet, no pump, no drum action and no timer motor even- this phase often confuses engineers but it is normal) after around 30 secs the machine will re start and should then ramp up to a slow, brief spin. after that it will progressively lead up to the full spin. Dont be tempted to speed up the programme by advancing the knob and if there is even a hint of out of balance it will skip the spin altogether. test empty to be sure, if it spins as above then it will be ok. IMO and assuming the pressure chamber is clean- Give it a squeeze, think milking a cow!.
I have never had a belt issue causing no spin and feel it is an urban myth. IMO!August 26, 2008 at 5:40 pm #260275JOHN CLARKE
Will be going to look at it sometime this week, will report back to the forum as to how I get on, B—-Y thing is built-in ofcourse.
August 26, 2008 at 5:49 pm #260276clivejameson
We get loads here with blocked pressure systems usually through soap over-dosing (same old suspect customers each time). If you ever get the sump hose off (total pig to refit BTW so don’t unless you really have to ) you’ll see the pressure hose end has quite a small aperture with a kind of flap too.
I usually manage to clear them with perseverance by squishing the hose while the machine is full of water…the really bad ones take a couple of attempts draining and refilling with clean water each time….September 2, 2008 at 6:53 pm #260277JOHN CLARKE
Thanks for all the help, I told him it would need a new motor in the end, at £179.00+VAT, I should think he did say no thanks.
