Diplomat 8512 , Washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Diplomat 8512 , Washing machine
  • #73190
    pedsthegoose
    Hi all
    In need of some help
    My Diplomat 8512 ,Is having some issues , It runs drains but not very well , And when it reaches towards the end of the cycle it wont spin dry , Is there some sort of cycle reset button ,
    Any ideas as to what i should try next
    Thanks Pete ::evil:
    #386683
    DrDill
    Re: Diplomat 8512 , Washing machine
    Have you checked the filter? and cleaned it out?
    #386684
    pedsthegoose
    Is that the filter , At the bottom front of the machine , if it is i have done that
    Thanks Pete
    #386685
    DrDill
    Take the filter out and have a god look inside to make sure there isnt anything inside. Put the machine on spin with out a load in and without filling with water, will it spin to full speed?
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #386686
    pedsthegoose
    No it will not spin to speed
    Thanks pete
    #386687
    DrDill
    Sounds like motor or module fault, best get an engineer out.
    Sent from my iPhone
    #386688
    pedsthegoose
    Well i have now fully cleaned out the filter & pump , And when you start a cycle it now fills with water as it should straight away , But now wont drain
    Pete
    #386689
    pedsthegoose
    I have now re-drained the machine , put it on spin seams ok ,There is a plastic strip in the filter would the placement of this affect anything on the cycle , As it does look as though it is part of the filer
