Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Diplomat 8702 Washer Dryer
- This topic has 9 replies, 4 voices, and was last updated 21 years ago by
admin.
March 31, 2005 at 10:14 pm #8782
KeymasterWe have a Diplomat Washer/Dryer in our rented flat that is about 1 month old. It has been working fine until last week, we did a wash followed by a dry and when we opened the door water spilled out all over the floor.
Then yesterday, even though there was no washing in the machine it hadn’t been used for two days and it wasn’t even switched on – it had filled up with water.
I’m guessing that water is coming back into the machine from the drainage pipes or something. Anyone heard of this before? Any help would be appreciated
Many thanks – Billy
March 31, 2005 at 10:24 pm #130458Dave_Conway
ParticipantRe: Diplomat 8702 Washer Dryer
Billio wrote:Anyone heard of this before?
Yes, many many times Billy.
It’s not been installed correctly and is back syphoning from the sink waste.
Get the kitchen fitters back and ask them to install it in accordance with the manufacturers installation instruction 😉
Basically the waste hose is too low allowing water (clean or otherwise) that goes down the sink plug to run down the hose in to the machine.
March 31, 2005 at 10:46 pm #130459admin
KeymasterRe: Diplomat 8702 Washer Dryer
Thanks alot for that Dave, I’ll get them back A.S.A.P. – typical scenario I suppose.
Keep up the good work!!!! – Much appreciated
April 14, 2005 at 11:43 am #130460admin
Hi guys I was wondering if you can help?
I have recently bought a flat and all the whitegoods came with the property. however I have all the instruction manuals apart from the washing machine. (You guessed it) The washing machine is a Diplomat 8702 washer dryer. Do you know where I can get a copy of the instruction booklet because I have been having some problems using the dryer programs.
Cheers
Stuart
April 14, 2005 at 11:47 am #130461kwatt
KeymasterMFI Stuart, there’s a link in the weblinks section.
April 15, 2005 at 12:01 pm #130462admin
Cheers
For that but I cant find the link on the MFI website. Could you post the link for me?
CheersStuart
April 15, 2005 at 12:16 pm #130463kwatt
KeymasterThere’s no link to request or download, you’ll have to call them I’m afraid.
April 15, 2005 at 12:26 pm #130464NWAR
ModeratorMFI Service 08457959722
Craig
May 1, 2005 at 3:41 pm #130465admin
Did you ever get the manual? I had the same problem and I cannot work out how to use the dryer function…so I contacted MFI and they were supposed to send me the manual. A month later I am still waiting. I really need to use the dryer!! Anyone help?
May 1, 2005 at 3:53 pm #130466kwatt
KeymasterFrom memory, make sure the half-load button is pressed and the dry timer set. The dryer cycle should start after the was/spin is complete.
