No / after model number on front of unit. Does that mean its a zero then?
Trying to avoid deinstall as dishwasher next to it has a nice square cut in floor replaced with nearly matching laminate :rolls:
Part number of module originally fitted is 546023701 DMPA H7.9 1200RPM.
Ordered EMW and received DMPA 9 H7. Notice resistors are 5K6 on new module. Old faulty module has 6K2 resistors fitted. Is this wrong and going to fail?
Also 2H10mins job took cause mate fitted kitchen with leaking and swivelly push fit plumbing with taps and waste miles away from collapsing water damaged cupboard and 2 inch thick floor up to machine :rolls:
Simon, i have used 5k6 resistors on these for many years with no repeat failures even. 6k2 is a non standard reisitance and are very difficult to source without having them specialy made. Should cause no probs mate.
