Diplomat 910S APL 4391 Main Oven Door Hinge Broken
Home Forums Public Support Forums Spare Parts Help Diplomat 910S APL 4391 Main Oven Door Hinge Broken
  • #35477
    Buwt
    One of the two hinges of the main oven door has become loose after it made a large bang as its sprung mechanism failed. Thus it can’t keep the door closed properly. The arm of the hinge still extends into its mounting in the oven casing so I can’t tell what has failed and how to get at it.
    Any ideas what has failed and how to replace it gratefully received?
    #246723
    mmm
    Re: Diplomat 910S APL 4391 Main Oven Door Hinge Broken
    the spring in the door hinge has broken, the hinge cannot be repaired.so a new hinge is required
    #246724
    Buwt
    Thanks – any idea how to dismantle the oven to get at the offending hinge and where to get one from?
    #246725
    Hi Buwt,
    This article explains how to replace oven door hinges
    However that’s the Stoves built one on which the hinge foot on either side goes, shown here and it’s not just as simple as many to do.
    HTH
