Customer sent pictures (on link below) re-door hinge adrift.I havent repaired one before…but it looks like a new hinge is required,also I feel it may require a rivet (not screwed)to refit (special order)…can anyone advise please. John
you’ll have to take side panel off first to confirm fault – spring may have broken or come off – if that is the case its just a matter of hooking hinge back on to rivet & replacing spring ,without taking panel off you will just be guessing- remember to check both springs.Its not a hard job.
Franz
