Diplomat adp-5701 oven selector switch question
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat adp-5701 oven selector switch question
  • #96853
    Paul Fletcher
    Hi I have just got a second hand diplomat adp-5701 range cooker and the lower element was not working .
    i have just installed a brand new lower oven element but it’s still not working.
    Would the next thing to look at be the oven selector switch ? At the moment it still works for everything apart from lower element modes .
    #465046
    Specialist01269
    Hi: For any further testing, you really need to have access to a Multimeter and know how to use it.
    #465047
    Specialist01269
    Sorry: Forgot to ask, was the element tested before being replaced ? & What did any testing show ?.
    #465048
    Paul Fletcher
    Hi thanks for getting back to me .
    yes I have a voltage tester , I didn’t test before hand as the person I got the cooker from gave me money off to get a new element so just ordered and replaced today .
    I’ve just done a continuity test on the old element and that does infact test ok .
    #465049
    Paul Fletcher
    Paul Fletcher wrote:Hi thanks for getting back to me .
    I guess the next step would be to check there is voltage at the element connection point .
    is the element connected directly (normally) at the selector switch ?
    #465050
    Specialist01269
    Hi: Due to the Dangers involved We don’t actually encourage live testing of appliances. That being said, we can’t actually stop you doing so.
    When you say Voltage tester could you explain further, do you mean a Multimeter or a Neon screwdriver ?.
    #465051
    Paul Fletcher
    Yes a multimeter, I understand you can not encourage live testing on circuits .
    im a audio/visual engineer so competent to test on live mains/low voltage circuits .
    #465052
    I would trace the wires from the lower element back to the selector switch and look for signs of burning or contact damage
    Paul Fletcher
    Ok great thanks Dave.
    do these selector switches commonly give up on one mode or generally give up completely ?
    #465054
    all is possible
    just depends which contact fails
    Paul Fletcher
    Ok makes sense
    thanks again for your advise.
    #465056
    Specialist01269
    Hi Paul: If you don’t have 240v to the element, you need to find out whether the Live or Neutral is missing and trace that side of the supply back to where it disappears.
