Re: Diplomat ADP 8102 – Never stops
It doesn’t take hot water. The timer stops and turns the heater on. The thermostat will complete a circuit when the water reaches temperature and re-start the timer. Therefore, your machine is probably not heating the water.
Possibilities are heater failure, broken wire at the pivot point in the door, safety stat tripped out, or timer not switching the heater on.
Power off if you intend to deal with this yourself.
