Diplomat ADP 8112 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat ADP 8112 Dishwasher
  • #41372
    WhiteVanMan1
    The machine is showing an aquastop/leak fault9lights 1 and 5). There is no leak, but the pump is cycling on and off. The sump switch is not activating though, which is throwing me a little. Has anyone come across this? As I would like to go with as much info as possible before I go and take it out. Cheers. Steve
    #269922
    Marty-K
    Re: Diplomat ADP 8112 Dishwasher
    I had this problem some time ago. It turned out to be the pcb at fault but you need to be sure you`ve eliminated everything else because its an expensive part to get wrong ❗ (Pt No 816290672 retails at £140 and available from connect for £95 + vat).
    Regards
    Marty
    #269923
    check that dispenser coil before doing anything!
