Diplomat ADP 8112 – Door not opening
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP 8112 – Door not opening
  • #54396
    bjbear
    After 7 years the dishwasher doesn’t open at the end of the cycle. Up until then the door appeared to capable of being opened at any time although there was a recommendation not to do so mid cycle for obvious reasons. Why would the machine start to lock itself?
    #319465
    Re: Diplomat ADP 8112 – Door not opening
    Handle or latch mechanism (probably) broken. Excessive use in opening the door is approved…
    bjbear
    Penguin45 wrote:Handle or latch mechanism (probably) broken. Excessive use in opening the door is approved…
    Thanks for the advice on excessive force – I have used it aldready. Not too much needed. The locking system is a square wire loop and tab that rises into the loop. It rest the tab is up 3mm which is half way up in the receiving hole. What I don’t know is how far the tab should rise.
    #319467
    It’s a “turn over” mechanism. Look into the slot at the top of the door and you should see two fingers or blades pointing at you. When these hit the wire loop, it should flip round 90 degrees to lock the door and work the master switch. It’s a known weak spot – replacement is your easiest option.
    It’s HERE; not particularly expensive.
    gandh1
    Penguin45 wrote: and you should see two fingers.. ..pointing at you
    couldnt help but lolollolll at that slip 😛
    #319469
    Que?
    P45.
