Hi all, my nan has the above mentioned dish washer, ser no 05218 0300, type 12041.
Initially it was starting for aprox 2 minutes then stopping without error codes. I’ve tried the reset several times to no avail, however I did get error e2 second light solid fith flashing, too much water float has tripped, I cleared this code and tried again and now the machine is dead and will do nothing but show a new code of e3, first and second solid and faith flashing un able to heat water.
The manual is not much help as it states it’s for a adp 8221.
Have had the machine switched off at the mains but the fault shows as soon as it’s switched back on.
All help appreciated.
