Diplomat ADP 8132
  • #41606
    harvey
    Hello folks,
    Wonder if someone can assist with this:
    All seems well, all the programs can be selected, it powers on and off.
    But-whichever program is selected it just won’t start up. (i’ve tried the re-set procedure elswhere on this site but no luck)
    Well, i thinks it’s the procedure- it needs the program button to be depressed constantly for around 3/4 secs rather than four quick pushes to get the two outer lights to flash but i presume this is correct???
    Anyway, any advice very much appreciated,
    Thanks in advance…
    #270725
    clivejameson
    Re: Diplomat ADP 8132
    This could be a number of known faults…the most common being a faulty dispenser coil or an earth fault on the heater or mains suppressor, or even a faulty pcb. The only way to find it is to chase around with a meter.
    Holding the program button down for several seconds aborts the program and runs a set draining period before stopping, and pressing the button four times after switching on accesses the service test program 😉
    #270726
    harvey
    Re: Diplomat ADP 8132 faulty,won’t start up
    Thanks for your help,
    Is there anything i should try or is it engineer time??
    Cheers!
    #270727
    clivejameson
    Well it’s highly unlikely that a button push will sort it so unless you can master a meter then yes, it’s time for an engineer.
    You can try the link below for a reputable local indie who will be able to sort it for you 😉
