My Diplomat ADP 8132 stopped filling and washing a little while ago. Acting on the advice of a Diplomat service technician I replaced the airbreak.
However, the machine is still not working. Here are the fault symptoms:
The machine makes up to four attempts at loading water but interrupts fill cycle every time and discharges.
After fifth try machine starts washing cycle which is then terminated prematurely after about 2- 3 minutes whenn machine beeps, discharges and displays fault code E2.
Any advice as to possible source of fault is much appreciated. Could this be a faulty pressure switch or control PCB (in which case I’d probably be better off financially buying a new machine?).
Thanks very much in advance
JRG
