Just been out to this one this morning door catch had rolled over reset that and tried machine all leds are ok chose a cycle,shut door.
Drain pump kicks in for about a second then stops for about 2 seconds then starts for a second and so on, it won’t stop doing this on any cycle, heater tests ok no visible damage on board all connections ok no damage to wiring harness this mod has a pressure switch “no flow sensor” the machine will not let water in, put some water in the machine manualy made no diffrence pumped the water out by activating the flood protection switch.
Has anyone any more ideas?
Auldyn Electrics
