I can not find this code mentioned before, hence starting a new topic.
My Diplomat ADP 8132 was working well, but yesterday took over 3 hours to complete the economy cycle.
The lights show: 1,3 & 4 fixed on
2 off
5 flashing
These will not change pushing the reset.
I have tried resetting the pcb as detailed elsewhere several time.
I have taken the pcb out and could not see any signs of burning out (I am an electrician).
I have completely drained the system and reset the heater push button (It was ok and did not need resetting).
I put it all back together and though the program selector microswitch was working the light sequence did not change from above.
The washer started its cycle, but after about 5 minutes keeps beeping and sounding as if its restarting (as if in a program loop).
I am wondering if it is the PCB that has failed.
Any thoughts please?
