Diplomat ADP 8221 Stopped Working
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP 8221 Stopped Working
  • #30555
    vick27
    My Diplomat ADP 8221 integrated dishwasher stopped working after it had filled. There is power to the dishwasher as the on/off button functions but none of the programmes are working. When the start button is held down there is not the usual click to indicate the programme is ready to start. Just silence. The dishwasher is about 8 years old. Is it worth fixing, or should I just go shopping for a new one? I am in FY8. Thanks. :rolls:
    #227628
    Re: Diplomat ADP 8221 Stopped Working
    Mechanical timer on these old beasts. If you can remove the front wooden decor panel (special tool required to pull the spring loaded retainers out but I am sure you can improvise). You will see in the top rh corner of the facia panel, a hole where, if it were not a built in model, the timer knob would be. Carefully insert a screwdiver and turn it one click CLOCKWISE and the programme will continue then. If on the next wash it does the same then you have a problem and need an engineer. Sometimes these just lock up for no aparent reason for a temporary blockage that has since cleared itself.
