Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Diplomat ADP 8224
- This topic has 8 replies, 3 voices, and was last updated 20 years, 2 months ago by
cornwell40.
January 30, 2006 at 10:27 am #15240
cornwell40
ParticipantThis one isn’t heating.
Checked the usual loom, heater etc., on this model as far as I’m aware there isn’t a reset stat (unless it’s very well hidden).
The board looks ok as I’ve had these before where the relay goes down but in the past there was visible distortion to the casing.
Any other ideas??Tony C
January 30, 2006 at 12:17 pm #162738Dave_Conway
ParticipantRe: Diplomat ADP 8224
Is it finishing the cycle and no error codes displayed Tony ?
Possibly the thermistor in the door ?
January 30, 2006 at 7:58 pm #162739cornwell40
cHECKED THE THERMISTOR. CAN’T REMEMBER THE READINGS 😳 Sorry I’ll stop shouting 🙁
but with my meter across the terminals and a heat applied the resistance was dropping.Tony C
January 30, 2006 at 9:39 pm #162740Dave_Conway
Is it completing the cycle though with no error codes ? 😉
January 30, 2006 at 10:46 pm #162741cornwell40
Pretty sure she mentioned F5.
Tony C
January 30, 2006 at 11:02 pm #162742Dave_Conway
If it was E5 it’s a no fill error.
I think this one needs to go a full cycle (if it gets that far) and see exactly what’s happening as far as the PCB goes before condenming it.
I can’t tell if the stat by the heater is a manual reset type or not but it’s a 4 tag and both contacts (according to the wiring diagram) ahould be NC.
January 31, 2006 at 5:09 pm #162743cornwell40
Sorry fault was E3 😥
The stat by the heater was linked out for a test but still no heat.Tony C
January 31, 2006 at 6:01 pm #162744Dave_Conway
Temperature 22°C 45°C 54°C 55°C 60°C 65°C 68°C 90°C
Resistance 8.9KΩ 5.7KΩ 4.4KΩ 4.7KΩ 3.5KΩ 3.1KΩ 2.7KΩ 2.0KΩLook what I found 😀
If that isn’t it then it can only be the PCB I guess 🙁
January 31, 2006 at 6:04 pm #162745eastlmark
ModeratorRe: Diplomat ADP 8224
the relay contacts often burn out, the very sharp of hearing may even here the click when the relay energises if not Check for minute dry joints on the LOW voltage side of the relay.
