Diplomat ADP 8224 dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP 8224 dishwasher
  • #5986
    Water does not enter my dishwasher chamber, although it does seems to enter the machine but gets pumped out.
    Any ideas?
    I recently replaced the pump and water does drip through a side (overflow) into the chamber but no water is sent through the cleaning arms.
    Hugh
    #114958
    DentedPorsche
    Re: Diplomat ADP 8224 dishwasher
    Crushed the fill hose when you put the machine back perhaps?
    Are you getting any error codes flashing?
    #114959
    No don’t think so, opened the side panel with the machine away from the wall and could see water entering the machine.
    But I omitted that nothing is displayed on the display!
    #114960
    Dave_Conway
    Which pump did you replace, drain or wash ?
    I think you’re wife (I assume anyway, correct me if i’m wrong) posted the same query a week or two back.
    It sounds to me as if the dishwasher is actually filling but the ciirculation motor isn’t running or the overflow protection system is permanently activated.
    I would look at what you’ve already done and check for incorrect wiring, wires accidently pulled off terminals, or did you/someone misdiagnose in the first place and this has been the fault all along ?
    Regards.
