Re: Diplomat adp 8227
There appears to be ADP 8221, 8224 and 8226 – no 7……… All SMEG made machines. If it’s the 5 led machine, E7 is flow meter fault, when no flow meter is fitted. Proceed as follows:
Reset Procedure
Switch on and press the programme button 4 times, within 3 seconds. The 1st and 5th lamps should light…….. You may have to do this several times before it works! Assuming that it does, switch off, count to 10, switch on and run the rinse programme only.
From P4 of “Known Error Codes” thread at top of forum.
