Diplomat adp 8234
  • #6915
    When switched on, dishwasher machine shows E2 on display. No manual with machine, does anyone know what could be the problem?
    #120296
    Hi Paul,
    It’s a fill error most often caused by a blocked side chamber and it’s not a DIY job to put right. If you try the directories or pop up your postcode I’m sure someone will be able to assist you.
    There’s also loads of info on this fault for various models throughout the forums.
    Re: Diplomat adp 8234
    Thanks for the quick response.
    My postcode is PR4 area
    Paul
    #120298
    Dave_Conway
    There’s a couple in your area Paul, if you follow this link:
    http://www.ukwhitegoods.co.uk/search/fi … ineer.html
    Regards
