Re: Diplomat ADP 8234 – will not startup!
Do you have a test meter? If you have, with the power off, you will be able to test the function of the door switch. If you haven’t, your only realistic option is to seek professional help. I assume from the posts so far that your appliance accepts the programme – it needs the door switch to activate to say “Go” to the computer board. Otherwise you are looking at a board fault – the computer is not recognising that the door is closed.
Check Repairs@ or Directories for a UKW repairer in your area.
If you wish to carry on – pull the plug first. :plug:
