Diplomat ADP 8242
  • #7156
    Have problem with dishwasher. When i opened door there was quite a lot of water in bottom. I have checked filters and cleaned them. now when we switch on power none of the programme lights come on. Is this terminal or is there anyone who can help resolve the problem
    #121709
    Dave_Conway
    Re: Diplomat ADP 8242
    This shouldn’t be too serious CWH, certainly not terminal anyway.
    It’s just not draining which could just be a simple blockage or possibly a drain pump failure.
    Check the waste hose where it joins the sink trap (if it does) or wherever it connects to for blockages 1st.
    If all seems well, you’ll most likely need an engineer to rectify for you.
    If you let us know your postcode should you need an engineer, there’s plenty here who can help.
