Diplomat ADP 8242
  • #9367
    My fully integrated Diplomat dishwasher (ADP 8242) is not working. It starts for about 4 minutes then you hear a bleep, when you open the door the first three lights (from the left) are flashing. When you close the door and open it again only the 2 right hand lights are flashing. It does not seem that any water has entered the machine. I have tried switching it off at the mains, checked the filter inside the machine and also checked the pipes at the back of the machine for any creases. My manual does not show any of the above faults. Can you help? Thanks!
    #133732
    NWAR
    Hi Jane,
    It sounds like your timer needs reset. I’m afraid I can’t detail the procedure here but if you check back through the dishwasher threads there should be some tips on this.
    Craig
    #133733
    Jane
    Re: Diplomat ADP 8242
    Craig
    thanks very much, found the exact same fault and the sequence of buttons to press on how to reset it. Will try it out tonight, hopefully it work and there will be no more washing up!!!
    thanks
    Jane
