Re: Diplomat ADP 8242 – Door Stuck closed
The answer is to grab hold of anything you can at the top (plastic) of the door and pull like fury! It will inevitably break but it is broken already where it supports the latch which is why it’s stuck. The mountings for the machine if installed correctly are hidden above the facia so you won’t be able to slide it out with the facia in place anyway.
The latch itself will be worn and might break too but even if it survives I personally would recommend replacing it with the facia. The latch ‘holds’ on to a metal striker fitted to the top of the cabinet so you are unlikely to do any other damage.
Tough job which I have seen on a few occasions but thats your only solution I’m afraid 😕
