Diplomat ADP 8322
  • #9499
    Hope you can help me out!
    My machine is an entegrated unit and when I set the program and close the door for the machine to start there is a constant beeping sound(similar to the sound at the end of the wash cycle) this does not stop until the door is opened. When the door is opened the light that indicates which program is selected has jumped to the rinse cycle and the power indicator is flashing.
    Can you help?
    #134301
    Dave_Conway
    Re: Diplomat ADP 8322
    I don’t have the relevent info to hand here, how many lights in total are there and can you let me know which one’s are flashing and which are static, counting from the left.
    #134302
    DentedPorsche
    It’s a Whirlpool machine, the start light will flash, pause, then repeat the flashes. Count the flashes on the start light and post the result here. Someone will translate it to the fault code.
    DP
    #134303
    There are 5 lights indicating the number of programs then the power button along the right hand side of the top of the door. The first light is solid being the rinse program, this is the one it jumps to after closing the door after selecting any other program. The power button is the one that is flashing and i tired counting the flashes but it seems to be a constant flahing, i counted over 30, is this normal?
    Thanks for you continued help.
    #134304
    Dave_Conway
    It’s probably just a single flash in that case.
    If so, a simple enough repair to resolve, normally the thermistor causes this. 😀
    Check repairs@ and the directories for an engineer in your area.
