I’ve just moved house and i have the above integral dishwasher fitted & I have no instruction mannual. I’ve used it several times and now when i try to use it it will not work. After i shut the door there is about a 15 second silence and then it beeps. When you open the door the button on the far right hand side flashes on and off and you then cannot do anything apart from turning it off. I’ve read comments about resetting it and mopping out the tray at the bottom. As i have no instructions i’m not sure what to do. Can someone please help…… 😕 i’m using tablets, is this also a problem?
Is the light just flashing constantly or is there a sequence to it ?
It sounds like the usual NTC error to me, if it’s just pulsing on and off, type “NTC and Whirlpool” (exactly that without the quotes) and you’ll find plenty of info on this fault 🙂
After further reading on the site it appears to be a F4 error. It keeps returning to the rinse cycle and then beeps and flashes. Can you tell me what the error is? Thanks 😀
This could be caused by any number of failures but check for blockages etc, power off if going inside :zap: or if you’re unsure, please check the repairs@ link below for a local engineer 🙂
