Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP 8322 – slight leak at top of door – but tried pretty much everything!
- This topic has 6 replies, 2 voices, and was last updated 5 years, 4 months ago by
smithie.
November 24, 2020 at 8:08 am #98703
smithie
ParticipantHi All,
I’ve got the above dishwasher, pretty old but works/washes great so reluctant to get rid. Recently there has been a small leak/gap at the top of the door but only on the left side, steam seeps out of the top and caused damage to cabinets. when opening the door I can see water droplets on the seal area and above.
What I’ve done but still have the issue-
1. replaced the main upper seal
2. replaced the lower seal (was old and knackered)
3. replaced the door hinges – thinking it was the door hinge that was bent causing the door not to sit flush
4. checked machine is level – which it is.
5. I’ve added some silver gasket tape to see if that closes the gap seal but no joy.I’m pretty much stuck with any other options, if anyone can help?
The design isnt great as there is one central strike plate holding the door in place but the seal is on the inside of the metal unit which the door has to meet but is only held in place by the sole strike plate…the left side has a tiny bit of play which seems to be the cause of the leak.
SmithieNovember 24, 2020 at 9:55 am #473451electrofix
ModeratorI cant remember properly but some units allows the door striker to be adjusted
November 24, 2020 at 10:10 am #473452smithie
ParticipantThanks Dave,
Unfortunately not on this one, the strike is fed into a metal brace and is a one piece that catches the door.
rgds
SmithieNovember 24, 2020 at 10:33 am #473453electrofix
Moderatorthere are a number of models with this model no
what is the 12Nc number normally part og numbers on a long bar code
November 24, 2020 at 10:47 am #473454smithie
ParticipantHi Dave
Labels show: Service 8545 000 15810 SER: 33 0417 011412
Diplomat ADP 8322 Typ NIC
Thks
SmithieNovember 24, 2020 at 10:55 am #473455electrofix
Moderatorsee what you mean you have the plastic latch on yours which as you say is fixed
nothing i can think of at the top od my head unless the door lock is not pulling it in as it did
November 25, 2020 at 10:02 am #473456smithie
ParticipantJust in case it helps anyone, I pulled the gasket out a bit and used some Fernox LSX to hold it in place (on the sides only), added a couple of strips of aluminium exhaust tape to the door where the two meet and the leak has been cured.
Thanks Dave for replying..
Smithie
