diplomat adp 8332 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries diplomat adp 8332 dishwasher
  • #26777
    suedehead1
    i went to this dishwasher today serial no. 8545 0021 5820,it had been coming up F4 .
    when i tried it it filled up with water then there was a repetetive clicking noise coming from the pcb.
    i took the door apart then disaster struck, a small white plastic thing about 1″ square by 1/8″ thick with 2 grey wires going to it came away from the door, i cannot see where this thing came from i tried to fit it into the soap dispenser and door lock to no avail. the 2 grey wires go to the pcb where there are the letters KL.
    can anybody tell me where this part goes, and what it does and if the machine needs a new pcb.
    thanks in advance.
    #211330
    suedehead1
    Re: diplomat adp 8332 dishwasher
    any ideas anyone?
    #211331
    Are you sure that is not the reed switch from the dispenser? that has grey wires sounds like it has pulled out of its slot.
    The original fault is usually either a problem with the water pressure switch thing in the sump, either its faulty or covered with crap. Or even a blocked filter can give that fault.
    #211332
    Lawrence
    eastlmark wrote:Are you sure that is not the reed switch from the dispenser? that has grey wires sounds like it has pulled out of its slot.
    Thats what it sounds like to me
    Lawrence
    #211333
    suedehead1
    thanks for the replies guys.
