Have just moved into a rented house with new ADP8332 but no manual. Can someone advise what is the recommended procedure for adding salt. Live in London area. Thanks!
If you give MFI a call on 0845 7959722 they will (for a samll fee) send you a new instruction manual for this machine.
There is a procedure for programming the machine to recognise your water hardness (and therefore use the correct salt dosage) which is explained in the manual.
