I have a Diplomat ADP 8342 dishwasher and everytime I switch the dishwasher on then select any program, shut the door the machine bleeps 8 – 10 times and the 2nd & 3rd program lights constantly flash.
I poured some water into the machine and tried to run a program and the machine quickly drained the water from the machine so it doesn’t appear to be a drainage issue.
Re: Diplomat ADP 8342 will no longer run a program
Despite your assertion that the machine is draining the water away, the code listed is the no drain error. It may be that there is a fault with the water level control system rather than a physical blockage.
Power off if investigating further, click the link below if you’re not sure how to proceed.
hi penguin,
Thanks for your response. I have doubled checked drainage and the machine is definitely draining. If it is a water level control system problem then is it simple and costly to fix? or even worth fixing?
