Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP 8352 first three lights on programme indicator
- This topic has 5 replies, 2 voices, and was last updated 18 years, 6 months ago by
Kl22222.
October 24, 2007 at 5:55 pm #31653
Kl22222
ParticipantHi I have a Diplomat ADP 8352 and the first three lights on the programme indicator keep flashing when switched on.
The lights are the heavy duty, normal and light wash programme lights.
Any idea what this error means?
October 24, 2007 at 6:58 pm #231958Penguin45
ParticipantRe: Diplomat ADP 8352 first three lights on programme indica
Flood protection activated – the tray under the machine is full of water. Drain tray and find the leak.
Note – multifunction tablets produce excessive foam in these machines, which can lead to the undertray flooding. Opening the door whilst the machine is operating can cause the tray to flood.
Put ‘Haier AND dishwasher’ into the Search facility for this forum only for an indication of what your up against with these Chinese machines.
Power off if you plan to sort this yourself.
Penguin45.October 24, 2007 at 7:05 pm #231959Kl22222
ParticipantThanks for the reply… when you say the tray. do you mean the sump where the filter fits into?… because I have had to soak up water before there, but that has not worked in this case.
Had no choice in this machine i’m afraid… it came free with the kitchen but have seen a few bad reviews since then…
October 24, 2007 at 7:10 pm #231960Penguin45
No, the tray across the very bottom of the appliance.
Free is still too expensive……
October 24, 2007 at 7:13 pm #231961Kl22222
Oh ok….. Not seen any tray on the bottom… how do i access that? All I can see underneath is a big black panel at the front… if it is more inaccesible then I may need to call in an engineer
October 24, 2007 at 7:18 pm #231962Penguin45
The black panel is the lower front cover, the undertray/base panel is below that – it is the bottom of the machine. Normally, you need to remove the machine from the housing for full access.
If you are not sure how to proceed, please use the link below for a UKW engineer in your area.
