Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP 8500 Dishwasher – Pulsing.
- This topic has 8 replies, 3 voices, and was last updated 19 years, 2 months ago by
KEVSWI.
January 28, 2007 at 6:13 pm #24566
KEVSWI
ParticipantHi,
When turning the dishwasher on today it worked for a few seconds but then started pulsing. Both the lights on the front pulse simultaneously and it sounds like the pump is trying to pump the water.
Any ideas?
Kevin
January 28, 2007 at 6:38 pm #202507Penguin45
ParticipantRe: Diplomat ADP 8500 Dishwasher – Pulsing.
Check for leak underneath (like last time 😀 ). If the motor terminals have got wet, you can get these symptoms. Otherwise, most likely the compuer itself.
Power off, if having a look.
Penguin45.February 5, 2007 at 11:25 am #202508warby111
Penguin45 wrote:Check for leak underneath (like last time 😀 ). If the motor terminals have got wet, you can get these symptoms. Otherwise, most likely the compuer itself.
Penguin45.Hi mate,
Excuse my igonrance but what is the best way to check this out? I have exactly the same problem with my dishwasher.
Cheers
February 5, 2007 at 8:35 pm #202509Penguin45
The lowest point of the machine is an “undertray”, which can fill if the appliance leaks for any reason. Access is best achieved by removing the decor door, then the front lower panel.
Ensure power is off before touching anything.
Penguin45.February 5, 2007 at 9:56 pm #202510warby111
Penguin45 wrote:The lowest point of the machine is an “undertray”, which can fill if the appliance leaks for any reason. Access is best achieved by removing the decor door, then the front lower panel.
Penguin45.Cheers for that mate will try have a look tomorrow would you mind me looking for advice again if need be?
Anything else could cause this problem??
Cheers
February 5, 2007 at 10:19 pm #202511Penguin45
There’s always somebody about to answer questions………
Check first post, those are the options.
February 10, 2007 at 6:36 pm #202512warby111
Hi penguin,
I have stripped the door and front off the dishwasher and it is as you said wet inside here. Where do i go from here now?
Also why does this happen?
Cheers
February 10, 2007 at 6:54 pm #202513Penguin45
warby111 wrote:I have stripped the door and front off the dishwasher and it is as you said wet inside here. Where do i go from here now?
Drain water, get everything dry.
warby111 wrote:Also why does this happen?
This is a common culprit:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
Observation to find the leak only course of action.Regards,
Penguin45.February 10, 2007 at 8:29 pm #202514warby111
Cheers Penguin mate, thanks for the advice,
I have now dried out the bottom area and the dishwasher is now running, going to leave the cover of whilst this is going to try find out the cause of the fault.
Judging by the link you also sent i would say it is fault 1.
Are there any tips you could offer to try diagnose correctly?
Warby
