Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › DIPLOMAT ADP 8502 FLASHING POWER LIGHT and NOT Washing
- This topic has 10 replies, 2 voices, and was last updated 18 years, 6 months ago by
davidgh.
September 17, 2007 at 9:13 am #30600
davidgh
ParticipantMy integrated dishwasher has stopped washing. It seems to wet everything and then stop. Sometimes it releases the soap tablet, but it does not fully dissolve. Was working fine prior to this. I’ve washed out the filters and rotor arms.
We are in a very soft water area: Taunton: TA1 3EJ
The power light is flashhing: four flashes then a break.
The serial number is 33 0327 013641
TYPE: NGPM
other number: service: 8545 001 15710
I have tried holding the power button for 20 seconds.
Any tips?
Thanks,
David
September 17, 2007 at 7:44 pm #227767Penguin45
ParticipantRe: DIPLOMAT ADP 8502 FLASHING POWER LIGHT and NOT Washing
If you open the door when it’s running, do you get wet?
September 17, 2007 at 7:58 pm #227768davidgh
No it stops when the door is opened.
September 17, 2007 at 8:19 pm #227769Penguin45
No – if the circulation motor was running, it would be spraying even as you open the door. You should at least see water dripping from the top rotor arm.
This is worth a read:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159Penguin45.
September 17, 2007 at 8:38 pm #227770davidgh
There is definately water circulating. It just does not seem to do the whole wash cycle. Are you saying the pump is broken or leaking?
Do you know what the flashing power light indicates? It flashes four times then stops for a second.
Thanks,
David
September 17, 2007 at 8:54 pm #227771Penguin45
Four flashes is drain failure – drop in water not detected in the time allowed. Usual problem is the black grid in the sump. This is the water level diaphragm switch and it fills up with semi-congealed fat and grease. You may get lucky scrubbing it out with a toothbrush and hot water, you may have to remove it for cleaning. It’s a twist fit from underneath.
Power off, of course.
Motor is probably OK – for now 😀 .
September 17, 2007 at 9:48 pm #227772davidgh
Thanks, I’ll try that in the morning.
September 18, 2007 at 6:53 pm #227773davidgh
Boiling water + caustic soda + a bit of scrubbing at the black grid by the filters and all working nicely now.
Thank you for the help. I did not even need to get under the machine.
I’ll make sure I use a dishwasher cleaner more regularly from now on.
Thanks again.
October 19, 2008 at 10:42 pm #227774davidgh
Hi Again,
Same machine has started playing up again.
this time it is flashing twice.
Any ideas?
October 19, 2008 at 11:11 pm #227775Penguin45
Hello again……
Water has leaked into the base tray under the machine and the flood protection float has been activated. This over-rides the programme. Drain the tray; if you get a repeat, find the leak. Bear in mind the link further up the thread about the naughty habits of your circulation motor.
October 20, 2008 at 1:50 pm #227776davidgh
Thanks for the prompt reply.
It was the old faithfull split pipe on the pump. Ridiculous that you can’t replace the pipe. Has no-one come up with a replacement pipe for it?
Not sure it is worth repairing – it has been a fairly crap piece of machinery from the beginning!
Can you recommend a good replacement? Your online recommendations seem to be out of date.
I need a full size, semi-integrated ( I think that is what they call them – the bottom panel matches the kitchen units, the top panel has the controls) white machine. Not too bothered about how many functions it has – only used one on the old one.
What is the best value reliable machine around these days, and can you recommend a good suppier.
many thanks for your help.
David
