Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP 8502 problem, please help!
- This topic has 10 replies, 4 voices, and was last updated 21 years, 2 months ago by
admin.
January 13, 2005 at 12:36 am #7444
KeymasterHi
I have a diplomat 8502 dishwasher that came with my kitchen “free” from MFI.
We returned from holiday yesterday so the machine has not been used for 2 weeks, and also my girlfriend put washing up liquid in it last night as we ran out of tablets, we got up to a puddle on the floor and the dishwasher not working. I dont have a manual to identify the a fault code but the single on/of light flashes in bursts of two. If I choose a program and hold down the on switch, it appears to start but after about 30 seconds stops. I have checked the outlet by filling it with hot water and it pumps the water out before it stops.
Is there anything I can check before I call an engineer out?Any feedback would be greatly appreciated!
Cam
January 13, 2005 at 12:53 am #123305Penguin45
ParticipantOh dear.
There’s nothing wrong with rubber gloves when you run out of tablets. Washing up liquid is NOT designed to be put through a high pressure pump and WILL froth like crazy. The machine almost certainly thinks it’s still full of water as the foam will trip the water level control.Safest option is to leave it for a while, then run the rinse cycle several times. The objective is to flush out any remaining washing up liquid. Be there when you do it, the machine may well flood and need resetting to drain.
This is a patience problem, don’t do it again!
Penguin45.January 13, 2005 at 1:17 pm #123306admin
KeymasterRe: Diplomat ADP 8502 problem, please help!
Thanks for the reply, is there any way I can reset the machine? I have tried turning off the power but this doesnt seem to work. There is only one button on this maching and a knob with 3 settings. No rinse setting unfortunately.
ThanksCam
January 13, 2005 at 1:31 pm #123307Dave_Conway
ParticipantRe: Diplomat ADP 8502 problem, please help!
Hold your finger on the start button for 20 seconds, that normally resets these.
This is a Whirlpool made dishwasher by the way 😉
January 13, 2005 at 2:21 pm #123308admin
Thanks for the info, worked a treat! Great site, saved me engineer call out fees!
Thanks again!Cam
June 2, 2007 at 11:07 am #123309ciderapple
Hi there,
I have the same flashing light on my diplomat 8502 (but this was not caused by washing up liquid!! I filled the machine with dishes this morning and this is what happened when I switched it on).
I have tried holding my finger on the button for 20 seconds but it just does the same program sound (actually sounds like it is trying to start draining or the sound it makes when the program starts at the very beginning just before filling commences) but then that sound stops and the light continues to flash.
There is no rinse setting on this machine, only three choices of program selected by turning a dial, so I can’t think of anything else to try.
Any sensible suggestions gratefully received.
June 2, 2007 at 1:41 pm #123310Penguin45
The base panel below the machine is flooded, and the protection system has been activated. Drain off to reset system, then find leak. The commonest one can be found here:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159Power off if doing this yourself.
Duplicate post deleted to avoid confusion.
Penguin45.June 2, 2007 at 4:07 pm #123311ciderapple
Thanks Penguin45, will give it a go and see if that solves it. Rubber gloves on until then!
June 3, 2007 at 8:11 am #123312ciderapple
Hi Penguin45,
OK, We did what you said and it worked a treat. Unfortunately now though it looks as though the cause of the flooding was another more fundamental problem. The machine starts any program, fills and then as the program gets to the point where it starts washing (I assume this is when the spray arms are supposed to start to rotate) it makes a horrible noise and stops, waits for ages drains a little and then refills again, goes throught the trying to start washing makes a horrible noise again and then waits for ages, only for the whole process to start again. It does this through the whole cycle and then drains and dries as it should, but obviously as the water has not circulated the machine properly dishes etc inside are still dirty. I am assuming that because the machine kept filling but only draining a little in the middle of the cycle this is why it flooded in the first place, it had obviously stopped mid-cycle due to the water in the cabinet.
Do you know if this is a problem with the progam control and how to fix it, or are we going to need a new control panel?
Thanks.
June 3, 2007 at 8:40 am #123313admin
Ciderthe problem will be most likely the main wash motor assembly that will need to be replaced due to either the rubber hose perished or that its an askol type motor.
Bryan
June 3, 2007 at 5:10 pm #123314ciderapple
Thanks Bryan – looks like I’ll be dipping into the bank account then.
