have solid lights on 4-5 on the programme indicator panel.
the pumps trys to run but stops with a alarm beep and then does the same process over again. Not to sure on the programme reset if i am doing it right, if that is problem.
Had to have the mains suppressor changed due to a fault taking out the rcd.
