Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP 8902 not progressing/finishing cycle
- This topic has 6 replies, 4 voices, and was last updated 13 years, 3 months ago by
akbmcf1.
December 11, 2012 at 12:02 am #72988
akbmcf1
ParticipantHi all,
Am hoping initially for some pointers as to where to start looking for a seeming fault with out Diplomat ADP 8902 slimline integrated dishwasher.
It’s just started running constantly, as though the cycle is not progressing or is not being told to turn off at the end. I’ve tried turning it off at the mains for a while (always worth a try!), but the problem persists.
It seems as though the rinse cycle is working as you’d expect, but not the wash cycles. Also, when you open the door, the water is warm, but not hot (this machine is cold-feed only).
Any suggestions as to what to check first?
Many thanks in advance for your help.
AndrewDecember 11, 2012 at 12:21 am #386144kwatt
KeymasterRe: Diplomat ADP 8902 not progressing/finishing cycle
Heater and stats first.
December 22, 2012 at 9:47 pm #386145akbmcf1
ParticipantRe: Diplomat ADP 8902 not progressing/finishing cycle
kwatt wrote:Heater and stats first.
Cheer kwatt. Have checked the heater element today with the multimeter – it had continuity and measures 28ohms resistance which looks to be about right.
Can you point me in the direction of the thermostat(s)? I couldn’t for the life of me see it looking up from underneath. As far as I could tell from the pic on espares, it’s a silver disc I should be looking for? Pic from here: http://shop.ukwhitegoods.co.uk/977870006-dishwasher-temperature-sensor
Once again, many thanks in advance for your help. I’ve always found this forum invaluable – it’s kept all our major appliances going when many people probably would have just bought a new machine.
January 10, 2013 at 12:47 pm #386146akbmcf1
Right, I found the thermostat in the door panel. I’ve tested it the only two ways I know – for continuity and resistance.
It doesn’t have continuity, but then if it’s acting as a switch (bearing in mind I’m a realtive n00b to all this) then that doesn’t necessarily indicate it’s faulty, right?
So I set my DMM to resistance, and am getting an infinity reading (display reads 1) at room temperature and when I put the thermostat in boiling water. Would this indicate the ‘stat is at fault? Or is it a case of just swapping it out with a new part and seeing if that cures the problem?
AndrewJanuary 25, 2013 at 2:47 pm #386147entech
Hi, I have exactly the same problem. Heater is working and I ran the door thermostat under some hot water and the resistance decreased to around 5ohms. Any more ides what problem can be? . Is the door thermostat just for cut out if it gets to hot or is this the only thermostat for checking water temp? It’s proving somewhat trouble to get this dish washer running correctly.
March 18, 2013 at 4:27 pm #386148entech
Hi all.
Problem still ongoing. Anyone have ideas. Really appreciate any help need it fixed.
Thank you.
December 9, 2018 at 1:48 pm #386149Diplomat8902
ParticipantI think I have the same issue. Thermostat and heating element both seem fine. Thanks
