We have a Diplomat ADP0150 600Ga Gas Oven within a tower unit (Model Number: 050502078) – whereby the glass within the Outer Door has shattered.
The glass appears to be the full size of the outer door and is also within the stainless steel frame of the door too, and not just the glass door window, that you look through.
Although shattered and in a million pieces at the moment, it is still within the oven door and havent as of yet fallen out, although I’s sure they would with a slight knock – so for the time being, we have secured this and not touching it currently.
We have been searching everywhere online and locally, including scrap yards, to try and find where we can buy a replacement door or the outer glass panel – but we are able to find replacements for the inner glass only, which for us we don’t need as ours is fine and completely in tact.
I know that the Company themselves are no longer trading and therefore a lot of their spares are now discontinued stock.
Does anyone know where we can go in order to find a replacement or solution?
OR if there are other models that we could use instead that would fit?
We are trying to hopefully not go down the route of buying a completely new gas oven, especially as other than the shattered outer glass door, it works perfectly – PLUS it is not used that often, so to fix it instead would be more beneficial.
Any help or advice would be greatly appreciated.
