Diplomat ADP3850 seems to be dead
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat ADP3850 seems to be dead
  • #47466
    thefuzzybear
    Hi there
    We have a Diplomat ADP 3850 Single oven which was working fine one moment and then seems to be dead the next. We’ve had it from brand new for almost three years and its been great. However, the display is now blank and when turning the knobs to use the grill or the oven nothing happens, the fan doesn’t turn and there is no heat.
    We have checked the power going in with a meter and there is power going into the oven just nothing else happening
    Any help will be greatly appreciated
    Many Thanks
    #293567
    Re: Diplomat ADP3850 seems to be dead
    If the display is blank and it’s an LED timer/clock it’s very possibly the timer that’s gone. I can’t seem to find that model number.
    If not do check it’s not on automatic
    Other than that, mains terminal block fried?
    thefuzzybear
    Hi there
    Thanks for the update.
    The display is an LED display and it does have a timer. However, it is blank and the buttons don’t seem to be doing anything
    I’m assuming then that this means that the Main Terminal Block is gone??
    If I may ask, whats one of these?? Can it be replaced?? Is it expensive to replace and is it worth it??
    #293569
    Assume nothing, test everything. 😉
    Mains goes to the terminal block and then to the timer, sometimes by way of a thermal cut out thermostat so that’s a possibility if one is there but, without a good model number I can’t check it for you.
    Mains terminal blocks are cheap and the sort of thing you can see here
    Thermal cut outs are usually not that expensive either.
    Oven timers however are often ludicrously expensive.
    HTH
    Washman
    Have you checked the fuse some of these single ovens are plugged into 13amp sockets .
    Washman
    #293571
    thefuzzybear
    I haven’t checked the fuse yet…I will be doing that next
    Also the model number that I read off the side of the oven is ADP3850
    The serial number if that helps is 06 106621 09
    Thanks for all your help so far 🙂
    #293572
    thefuzzybear
    Re: Diplomat ADP3650 seems to be dead
    Hi there
    Looks like I got the model number incorrect and it was actually ADP 3650
    We’ve opened it up and it looks like the clock/timer has gone 🙁 Based on this, we’ve decided to bin it 🙁
    #293573
    gandh1
    £50-60 for timer, so not cheap, but not as expensive as others!
    #293574
    thefuzzybear
    Thanks for all your help guys 🙂
