Diplomat ADP4230 ( 720EF ) cooling fan
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat ADP4230 ( 720EF ) cooling fan
  • #30094
    tdl1325
    Cooling fan DP200a replaced as old one tested open circuit. When new fan first fitted and power turned on, fan ran but would not stop. Clock/Timer reset and oven element turned on/off to see if timed cooldown would work. Fan ran for about 2 hours then stopped working altogether. Will not run at all now, tested ok for continuity and resistance about 500 ohm. 240v supply at terminals. Any ideas?
    #225877
    NWAR
    Re: Diplomat ADP4230 ( 720EF ) cooling fan
    That fan is controlled by a circuit board (around £30 give or take) which may have blown a track when the fan went.
    It may be worth getting an engineer in to diagnose & repair before proceeding with more parts though.
