Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › DIPLOMAT ADP4520 1400 watt fan element
- This topic has 7 replies, 5 voices, and was last updated 16 years, 12 months ago by
cookerfit.
April 15, 2009 at 9:15 am #44994
cookerfit
ParticipantI’ve got a couple of these to repair but have not been to site or seen one yet.
The 1400 watt fan element seems to be very low wattage – does anyone know if it operates on its own or in conjunction with another element?
They also seeem to have a high failure rate – is it just design, over use of the element because of its its low wattage to maintain temp or is there something else to be wary of???..Thanks
Cookerfit
April 15, 2009 at 5:14 pm #283229Jonah
ParticipantRe: DIPLOMAT ADP4520 1400 watt fan element
The lower wattage is only because they can be fitted with a 13amp plug top if no 45amp circuit is available, in fact the first models that came out only had a 1kw fan element in them and were soon upgraded to 1.4kw as they were extremely slow in cooking, it is the only element in the main oven, top oven is a weird set up and is very slow there was a modified kit available for the top oven but very expensive, might still be available from AW Services.
I have put in 2kw elements if appliance is connected to 45amp supply with no problems as the last versions produced did have a 2kw element fitted and could only be fitted to a normal cooker outlet, the ovens are made by Technogas for MFI so you can get pattern elements as well as genuine, hope this helps.
April 16, 2009 at 10:23 pm #283230cookerfit
Thanks a lot for the info, I’m sure many other engineers doing work for D&G on MFI units will find it helpfull 😀
Regards
CookerfitJuly 17, 2009 at 6:14 pm #283231mike412
Hi folks.
I need one of these elements. CDSL advises now obsolete, anyone know a part number source for a pattern spare. (or got a genuine on the shelf).
Many Thanks,
Mike.
July 18, 2009 at 8:47 am #283232Jonah
Part Number 524021800 1400W Fan Element
Email AW Services on: awservices1@btinternet.comJuly 18, 2009 at 7:11 pm #283233mike412
Thanks for that Jonah- email is winging its way now.
Regards, Mike
July 19, 2009 at 12:08 am #283234kwatt
KeymasterRe: DIPLOMAT ADP4520 1400 watt fan element
mike412 wrote:I need one of these elements. CDSL advises now obsolete, anyone know a part number source for a pattern spare. (or got a genuine on the shelf).
It’s not obsolete. 😕
Rubbish picture (yes I took it, I’ve gotten better since then) but it is HERE and can be ordered from AW or Masterpart, both stock it so far as I know. It’s a stock line for us as well. Not cheap, but available.
HTH
July 20, 2009 at 7:12 am #283235hyg-dip
Part in stock at AW Services 01603 630258
Andy
