Diplomat ADP5330 – Major Fan Noise
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat ADP5330 – Major Fan Noise
  • #34894
    only1salty
    Was wondering if anyone could help. As per the title have a;
    DIPLOMAT ADP5330
    Serial No. 3P0094A01671
    In the last 2-3 weeks the fan (I guess) has got progressively louder and louder until it is now so loud you can’t hold a conversation in the kitchen without shouting over it.
    The oven still heats up fine, still cools down fine.
    The fan noise starts a minute or so after turning the oven on and continues after the oven has been turned off (assume it is also used for cooling). When the oven is cool enough the noise stops and we all breathe a sigh of relief.
    It is a very loud rattling noise.
    Have searched the forum for a day but found no answers;
    – Is this a fault anyone has seen before?
    – Could it just be something touching the fan or is it more commonly a bearing?
    – Can I fix this myself (I am not afraid of a screwdriver) ?
    – I haven’t had a poke around yet because this is a dual fuel model and I don’t go anywhere near gas. However if I can poke around without moving it would like to try to fix it as cash is tight.
    Thanks in advance for any help
    Salty
    #244371
    Re: Diplomat ADP5330 – Major Fan Noise
    If it’s a fan which runs on after switching off, it will be the cooling fan at fault. This mounted on top of the oven, under the gas rails etc……..
    You really should get a CORGI engineer to it, I’m afraid.
    only1salty
    OK cheers
    if the fan runs during cooking and carries on after cooking is it still the cooling fan?
    does a cooling fan run during cooking? or does this model have just the one fan?
    #244373
    Two fans – circulation fan in the oven, which should shut off when the oven is turned off at the thermostat. The cooling fan is controlled by it’s own thermostat and will run on until the the thermostat cools and breaks the circuit. This can be some time after you have finished cooking.
    only1salty
    Thanks very much
    time for me to get a pro involved then.
    #244375
    only1salty
    Back for more!!
    Got a repair company to come and look at the oven. He said it was the cooling fan and the oven could still be used while he got a replacement cooling fan.
    A few days later the noise stopped and the oven started getting really hot to touch so told the wife to stop using it altogether as we have a young baby running around.
    This was 28 days ago and the repair company have told me 3 times that the part will be available in a couple of days.
    Now if they had said up front, this will take 30 days to get the part I could have least been prepared.
    Having stupidly paid in advance for the service I am loathed to go elsewhere and the actual engineer did give the impression he was professional.
    Can anyone help me source a part. The company are saying it’s a Hygena part on a Diplomat branded Oven but they won’t tell me the part number so I can try and source it elsewhere and speed the process up.
    Wife is kicking me as trying to provide 3 meals a day for 2 young kids without an oven is a pain in the rear.
    Any help much appreciated.
    #244376
    Part number is 2.12ABT013130 by Siltal and is usually a stock item so available in a few days normally.
    HTH
    Seems a good idea to me 😆
    Monday = Chinese
    Tuesday = Indian
    Wednesday = Pizza
    Thursday = Kentucky
    Friday = Liquid food at pub
    Saturday = Fish & chips
    Sunday = Pub lunch
    Sorted 😈
    Bryan
    #244378
    only1salty
    if I was rolling in it and not 16 stone already it would be great.
    Just to check – so this part is the motor. I don’t need the fan unit aswell do I?
    PS. Brilliant that you have these.
    #244379
    only1salty wrote:Just to check – so this part is the motor. I don’t need the fan unit aswell do I?
    That’s the complete unit with fan.
    only1salty
    actually guys don’t worry.
    Having phoned the repair firm who have been waiting 31 days for the part from their source I finally managed to get the part number from them and it was the same part number as you specified.
    What a fantastic website this is.
    Usual caveats from the repair guys apart parts differences,etc but they are the same part numbers they gave me aswell (also got the door seal).
    Oh and lastly you were £65 cheaper than the repair firm were trying to charge me.
    Thanks for your help. Would recommed you to anyone (assuming the bits turn up of course 😆 )
    #244381
    karv
    noisey cooling fan don,t allways mean its the fan but {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} is high, to see if its cleared it self or if its seized run oven for 10 mins tunn oven of if u hear blowing nosie its cleared its self if u hear nothing fan motor has seized ie new fan motor.
    noise can be from
    1) vibrating back panel on oven
    2) insulaton iie tinfoil looking stuff come abit losse and rubbing fan or crap loads of gunf on fan blade or fan housing is not tighten up
    cooling fan is run by a stat and will carry on after u turned oven of untill the thermal stat has cooled down.
    #244382
    only1salty
    Final Update
    So the part turned up within 2 days from your shop. All of them even the ones that said 7 day lead time (the seals).
    The firm that tried to charge me double the price for the parts turned up and fitted the parts you supplied.
    However they turned up with their own parts aswell :rolls:
    So after 6 weeks of chasing them because they couldn’t get the parts they turn up with their own. So in no uncertain terms the engineer was asked to fit the parts you supplied and take his own away and do what he wanted with them.
    All parts were correct and the oven has returned to a state better than ever. It must have been slowly on the way out for a couple of years (from when we moved in) because I never remember it that quiet.
    Anyway, all working and all good.
    Thanks to everyone on here and will recommend this site to anyone I talk to who has appliance problems in the future.
    Cheers 😀
