Have the above cooker. Recently a fault with the grill has occured. You turn the grill of and even though the dial is turned to off the grill keeps turning itself on and off still. Hence it gets very hot when not realised that its done it. Any suggestions on how to fix? :rolls:
Either the regulator has failed or the element has an earth leakage problem. You will need a test meter and the ability to use it correctly and safely.
If you’re not sure, please us the repairs@ link below for a UKW engineer in your area.
