Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Diplomat ADP5520 Range cooker – Main Oven
- This topic has 6 replies, 2 voices, and was last updated 12 years, 9 months ago by
Robin_Hood.
June 21, 2013 at 7:07 am #75938
Robin_Hood
ParticipantIs there an internal fuse on this model that would control power to the main oven? Having replaced the blown 30A cooker fuse in the consumer unit the small oven works OK but there is no sign of life in the main oven. If one component fails/is faulty does/should this prevent all other components from working e.g. light and fan?
I have checked the clock/timer and replaced the base element (as a continuity test by an electrician indicated that this had gone). Does anyone have any suggestions where to look next?
June 22, 2013 at 8:59 am #396683electrofix
ModeratorRe: Diplomat ADP5520 Range cooker – Main Oven
you have blown a fuse and as susch all sorts of things can blow
you said you checked the clock but have you checked the power is coming out of it going to the main oven switches
take out oven selector switch and look at the contacts see if one of the has blown
lastly check thermostat for continuity
hope it helps
June 24, 2013 at 8:20 am #396684Robin_Hood
ParticipantRe: Diplomat ADP5520 Range cooker – Main Oven
Thanks for your guidance. I managed to look at the clock and the power out connection had burnt out taking a couple of the other connectors with it. I have ordered a new clock/timer. What spec are the connectors/insulators likely to be as it look like I will have to replace at least a couple?
ThanksJune 24, 2013 at 10:27 am #396685electrofix
most people dont use the clock so you could have just bridged it so the clock tells the time thats all
connectors dont have a type as such but all connection have to be clean and tight.
ie if you crimp onto damaged wire it will cause heat and burn out very quicklyDave
June 24, 2013 at 11:00 am #396686Robin_Hood
Thanks again. The clock didn’t tell the time before it went bang! 🙂 The cook in the house (not me) claims a working (again) timer facility will be very useful. Should I replace all the wires that need new connectors or just trim them back (assuming there’s enough ‘slack’)? If so do I need a particular type of wire?
:worthy:
June 24, 2013 at 1:07 pm #396687electrofix
if you trim them back to clean wire it will be ok
if not you need heatproof wire suitable for about 10 amps
July 8, 2013 at 11:08 am #396688Robin_Hood
New clock/timer (from UK Whitegoods store) now fitted and working and main oven is working fine. 😀
Might need to fit some new door hinges for the sake of efficiency though 🙁
