Have got a couple of faults with this unit.
orginal fault the custome complained of was that continually washed.
Found that the thermostat had tripped so I reset.
It is now washing and heating but the programme continues to run without stopping. also found that there did not appear to be enough water being pumped up to upper spray arm as this did not move.
To try and drain unit I activated the float switch in the base but this did not bring on the pump :con:
Question is how can I reset/stop the programme? Do I have a wash pump problem?
Help does anyone have any clues or information on these beasts
Geoff
