Diplomat ADP8101/2 Integrated Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8101/2 Integrated Dishwasher
  • #7840
    No one seems to have had this problem before on the site so i thought i would ask….. deperately trying to save some cash.
    This dishwasher appears basic, a start button, hot/cold button. Rotary for cold rinse / off / wash. Three indicator lights Progress/Salt/Rinse Aid.
    Problem is this.
    After watching one too many house shows my wife put half a cup of bleach in to “clean” the inside of the washer. when the bubbles started coming out the sides she turned it off.
    Using a chicken baster i took all the water out, replaced it with new and tried again, same result…… so tried again, and again.
    Problem is the machine keeps running, never stops, never drains…..seems stuck.
    Any help or advice much appreciated.
    thanks
    Jools
    #125418
    Keep doing it – it’ll clear eventually. It is reluctant to drain because the bleach is turning the water to froth………
    Next time you want to clean it, use lots of lemon juice. Bleach is good for doing autowashers on the boilwash.
    Re: Diplomat ADP8101/2 Integrated Dishwasher
    thanks for the reply………. has now been running with a change of water (about the third change) for 3 hours…. far longer than a normal cycle……
    The water is not frothing any more, but it is also not heating the water at all.
    Any further advice….. is such a pain changing the water ( i use a turkey baster)
    Jools
    #125420
    Dave_Conway
    The element overheat thermostat will have “tripped” and needs resetting.
    If you’re not confident tackling this, then you’ll need an engineer to do it for you Jools.
    If you are going to have a look, whip the plug out of the socket :zap:
    #125421
    Since I know you do this……
    got any engineers you know in the CM24 area (Stansted way)
    thanks
    #125422
    or…… since i like a challenge……
    how do you reset the thermostat element……
    Jools
    #125423
    Dave_Conway
    bluejools wrote:got any engineers you know in the CM24 area (Stansted way)
    Go to repairs@ here:
    http://www.ukwhitegoods.co.uk/search/fi … ineer.html
    And enter your details Jools, there’s a UKW member in your area 😀
    bluejools wrote:how do you reset the thermostat element
    Sorry, I can’t give specific repair advice I’m afraid (EU regs etc..)
    #125424
    Dave and Penguin45
    thanks for your help with resoultion. I used the contact section of the forum as suggested, received very rapid attention from the local company who fixed the problem at the price quoted AND when they siad they would.
    Thanks for pointing people like me in the right direction
    Jools
    #125425
    Dave_Conway
    Great, thanks for taking the time to come back and let us know Jools :tup:
